wendong
how to Local data filter with today's date
We are trying to filter the date by today's date.
original line of code is Where( :DateOnly == "2020/02/27" ),
I try to replace the date by Short Date(Today()) or "Short Date(Today())", "|| Short Date(Today())||'  ; nothing worked, anyone can help?
Local Data Filter(
Width( 178 ),
Add Filter(
columns( :DateOnly, :Equipment ),
Where( :DateOnly == "||Short Date(Today())||" ),
Display(
:DateOnly,
Size( 172, 238 ),
Height( 238 )
Display(
:Equipment,
Size( 172, 51 ),
Height( 51 ),
"List Display"
wendong
Re: how to Local data filter with today's date
Thanks Jim for saving my day. ( I just need to change your line of code at the end from the semi colon to comma, then it works out)
Where( :DateOnly == format(today(),"y/m/d") ),
  1. Apparently your :DateOnly column is of data type character.
  2. The function Short Date() returns the format of "mm/dd/yyyy" and you need "yyyy/mm/dd"
  3. The format "y/m/d" will return that value and if you use the Format() function it will return it as the character string you desire
Where( :DateOnly == format(today(),"y/m/d") );
wendong
