jmp_ingbean
how do I add labels to a bar chart showing the N for each mean
vertical bar chart, where each bar represents the mean(col name)? no problem, done
now we want to show the N for each of those means, right at the top of each column
help? thanks
pmroz
Re: how do I add labels to a bar chart showing the N for each mean
You can do this in JMP 11 with Graph Builder.  Prior to version 11 you could only label bars using the Chart platform.
Here's an example that displays the bar label in JMP 11:
dt = open("$sample_data\Bands Data.jmp");
dt << Graph Builder(
    Variables( X( :ink type ), Y( :viscosity ), Overlay( :cylinder size ) ),
    Elements( Bar( X, Y, Legend( 2 ), Bar Style( "Side by side" ),
            Summary Statistic( "Mean" ), Label( "Value" )
In Graph Builder you use the label combobox to select Value:
ms
Super User (Alumni) ms
Try using a summary table with both Mean and N, with the latter labelled. Here's an example with Chart platform.
dtsum = dt << Summary( Group( :sex ), Mean( :height ), N( :height ) );
Column( dtsum, 4 ) << label;
dtsum << Chart(
  X( :sex ),
  Y( :Name( "Mean(height)" ) ),
  Label by Row,
  Show Labels,
  Bar Chart( 1 )
