Theresa
how can i save a JMP file as a name with time string?
how can i save big class.jmp as a name with time string? Thanks
e.g. dt = Open("$SAMPLE_DATA/big class.jmp");
Hope the script can identify the work week, and the day of week and add automatically on the name, thanks
Result i want:
save name as:
big class-ww12.1
big class-ww12.4
big class-ww12.5
Theresa
Re: how can i save a JMP file as a name with time string?
thank you so much. And would you check the question related with "Day" calculation?
Route="C:\Users\ywu64\Desktop\1\test data\";
dt << save(
Route || "New Data-" ||
Char( Week Of Year( Today() ) ) || "." || Char( Day Of Week( Today() ) ) ||
".jmp"
You need to study and learn the code.  Making the change from my original code to this version requires no new information.
All that has to be done, is to concatenate together the elements of the name that you want in the saved name
dt << save(
	"$TEMP/" || Char( dt << get name ) || "-" ||
	".jmp"
Theresa
Thanks a lot. May i ask if i want to save to below location and change a the csv file name to "new data", what should i do ? (final data name as "new data").
Location variables:
What should i do to change the name? and don't use big data any more.
dt << save(
".jmp"
Theresa
thank you very much, hope you have a lovely day.:)
Theresa
