anakar
how can I get data table from a graph?
Hey, I'm using JMP pro 13.
In my analysis I get a graph called the VIP (Variable importance plot).  I need the list of points on this graph for further analysis ball all I can copy is a picture of the graph. any idea how to get the actual data? like x,y values.
If it helps I made a PLS (partial least squares) analysis.
Cheers,
Amir
Re: how can I get data table from a graph?
Amir,
Go to the Variable Importance Table below the graph.  Right click anywhere in that table and select Make Into Data Table.
HTH.
Bill
Amir,
HTH.
Bill
anakar
Thanks, guess I couldn't see the forest for the trees...
I am right there with you.  Some days I can't even see the trees.
Peter_Bartell
Level VIII
And to pile onto my colleague Bill Worley's recommendation, many, many JMP analysis platform report tabular report elements are supported by this 'right click in the table body' to create a JMP data table of the report element.
acitretin
Dear All,
I have a big table of many experiments and I have created a bar plot, using graph builder, to compare one condition over diferent experiments. The graph builder already calculated the means and the STDEV. How can I export all the data which was  used for this graph inludeing the calculated means and SDEV.
Regards
Ahmed
