sebbeyer
getting a string from a list, where string contains defined text
can someone help me please? I have created a list that looks something like that:
{"C1234_here_is_some_text", "C1235_here_is_some_other_text", "C1236_you_get_the_idea", ..., "C2000_still_dont_ends_here"}
I want to get the complete string of the list where the first part of the string (e.g. "C1234") is "C1999".
Whats the correct code here?
Thank you in advance
Re: getting a string from a list, where string contains defined text
This is how I would do it
x = {"C1234_here_is_some_text", "C1235_here_is_some_other_text", "C1236_you_get_the_idea", ..., "C2000_still_dont_ends_here"};
found = "Not Found";
For( i = 1, i <= N Items( x ), i++,
	If( Contains( x[i], "C1999" ) == 1,
		found = x[i];
		Break()
show(found);
