h_lazar
get rows where returning empty matrix
I have a data table that I am trying to manipulate. I am using get rows where function to find where the first column equals a string, let's call it "aaa". When I use the software to do this, it works fine and two rows are selected, row 1 and row 2240. When I try to script this, the result is an empty matrix.
Here is the script I am using:
dtx = Current Data Table();
noRows = N Rows( dtx );
ddd = dtx << Get Rows Where( Column( dtx, 1 ) == "aaa" );
and the result is
[](0, 1)
note that this returns a 1
Column( dtx, 1 ) [1] == "aaa"
Does anyone have any idea what I am doing wrong?
thanks in advance
Heather
Craige_Hales
Re: get rows where returning empty matrix
I looks like Get Rows Where wants a simpler argument, try one of these
dtx=open("$sample_data/big class.jmp");
c=column(dtx,3);
dtx<<get rows where( dtx:c == "F" );
or
dtx<<get rows where( dtx:sex == "F" );
the odd looking returned value, [](0, 1), is JMP's empty array of 0 rows and 1 column.  the two examples return more rows, of one column:
[1, 2, 3, 4, 5, 9, 10, 11, 16, 17, 18, 19, 20, 28, 29, 35, 36, 38]
Craige
Craige_Hales
c=column(dtx,3);
or
Craige
h_lazar
c=column(dtx,3);
This did work, thank you both.
H
ms
Super User (Alumni) ms
A comparison of a Column object with a string will return always return false. In certain cases (or in general?) JMP must be expliticly told that you refer to a Column or to the Column values (I remember there has been a good thread about this maybe a little confusing difference but I can't find it now...)
You can access data with indices (as you showed above with Column( dtx, 1 ) [1] == "aaa"). In functions like Get Rows Where() that basically iterate through all column values, each value can be accessed with either of the below:
1) Column(dtx,1)[] == "aaa" // Note the empty brackets
2) As Column(dtx,1) == "aaa"
3) Or simplest with scoping colon as C Hales showed above
Craige_Hales
cool.  I didn't read the original question closely enough, and I'd forgotten about the empty [] anyway.
Craige
