volf
Staff (Retired)
fix text edit box width
Hi Jumpers,
As to fix Text edit box width, I put some spaces into Text edit box.
I want to know another way to fix Text edit box width.
regard
Volf.
Message was edited by: volf
Re: fix text edit box width
This thread may help:
http://support.sas.com/forums/thread.jspa?messageID=37505銁
volf
Staff (Retired)
Thank you David,
Your recommeded article contain to set dimensions of list box. This information is also very useful.
and I hope to know to set dimensions of Text Edit box. Specially, to set Text Edit Box width is strongly required.
regard
pmroz
This is an old post but I had the same issue and figured it out. You can set the width of a text edit box in a New Dialog window as shown in the following example.
win = New Window( "Example",
text = Text Edit Box( "Example Text" )
text << Set Width( 200 );
This is taken from JMP 9, Help > Displaybox Scripting > Text Edit Box > Set Width.
I put the width inside the dialog box as follows, which is a bit easier to follow if you have a lot of things in the dialog box:
text = Text Edit Box( "Example Text", << Set Width( 200 ))
Regards,
Peter
