walk545
fill missing data with conditions
I have a dt that has missing data that i need to fill from the same column.
the table tells us the color shirt someone is wearing i have a name, the date he changed his shirt, the next date he will change his shirt, and the color of the shirt.
my problem is that he doesnt change his shirt everytime he updates his data. if he doesnt change his shirt he writes "na".
i need to switch all the "na" with the color of the last time he changed his shirt. i need to fill the color conditioned by it being the same person and it being the last color recorded by him.
here is the table:
nameChange Shirt DateNext change shirt dateshirt color
Jay10/10/2019 22:1910/15/2019 18:49Yellow
Tom10/13/2019 6:0910/13/2019 18:25brown
Tom10/13/2019 18:2510/16/2019 5:56na
Jay10/15/2019 18:4910/18/2019 16:05na
Tom10/16/2019 5:5610/20/2019 2:31na
Jay10/18/2019 16:0510/22/2019 3:17na
Tom10/20/2019 2:3110/23/2019 18:41na
Jay10/22/2019 3:1710/25/2019 5:44na
Tom10/23/2019 18:4110/26/2019 21:14na
Jay10/25/2019 5:4410/28/2019 9:10na
Tom10/26/2019 21:1410/29/2019 2:02na
Jay10/28/2019 9:1010/31/2019 0:51Green
Tom10/29/2019 2:0211/2/2019 3:13gray
Jay10/31/2019 0:5111/3/2019 6:57brown
Tom11/2/2019 3:1311/3/2019 6:57na
thank you to anyone who helps.
ron_horne
Re: fill missing data with conditions
Hi @walk545 ,
Have a look at this solution. it is a bit low-tech but you should be able to get the result you want. just open the attached file and run the following script on it.
dt = current data table ();
dt << New Column( "Row", formula( :Row() ), eval formula );
dt:row << delete formula;
dt << Sort( replace table,
	By( :name, :Change Shirt Date, :Next change shirt date ),
	Order( Ascending, Ascending, Ascending ),
for each row ( if (:shirt color == "na", :shirt color = lag (:shirt color, 1)) );
dt << sort (replace table, By (:Row), order (Ascending));
A similar issue was addresses in this post https://community.jmp.com/t5/Discussions/help-creating-a-column-that-is-a-cumulative-sum-based-on-ot...
let us know if this helps.
Ron
ron_horne
Hi @walk545 ,
Ron
