vince_faller
factorial to degree script
I'm having a hard time making factorial to degree inside of a script in order to assign certain DOE factors to some factorial.
I can get the first level with nchoosekMatrix() but can't figure out how to dynamically get levels higher than 1.
Names default to here(1);
factorial_to_degree = function({factors, degree = 2, termlist = {}},
	{DEFAULT LOCAL},
	if(degree!=1,
		termlist = recurse(factors, degree-1, termlist);
	nckmat = nchoosekmatrix(nrows(factors), degree);
	for(r = 1, r<=nrows(nckmat), r++,
		AddTermExpr = Expr(AddTerm());
		for(c=1, c<=ncols(nckmat), c++,
			insert into(AddTermExpr, Evallist({factors[nckmat[r, c]], 1}));
		insert into(termlist, nameexpr(AddTermExpr));
	return(termlist);
factorial_to_degree([1, 2, 3], 2);
//returns
{AddTerm( {1, 1} ), AddTerm( {2, 1} ), AddTerm( {3, 1} ), AddTerm( {1, 1}, {2, 1} ),
AddTerm( {1, 1}, {3, 1} ), AddTerm( {2, 1}, {3, 1} )}
//want it to return
	AddTerm( {1, 2} ), AddTerm( {2, 2} ), AddTerm( {3, 2} ),
	AddTerm( {1, 1}, {2, 1} ), AddTerm( {1, 1}, {3, 1} ), AddTerm( {2, 1}, {3, 1} )
I think I should be doing something recursively but I'm having a hard time actually getting anything to work.
Any help would greatly be appreciated.
Vince Faller - Predictum
vince_faller
Re: factorial to degree script
I realized that my expectations were not right.  This actually does the same thing as what fit model macro does.
I like the following iterative approach more though.
factorial_to_degree = function({factors, degree},
	n_factors = nitems(factors);
	factors = shape(factors, n_factors);
	termlist = {};
	for(i=1, i<=degree, i++,
		nckmat = nchoosekmatrix(n_factors, i);
	return(termlist);
vince_faller
	termlist = {};
	return(termlist);
