sujerwood
exporting the surface profilers
Hi, I am new to the community. I am trying to figure out if there is a way of exporting the 3D surfaces created as a result of the DoE analysis.
thank you,
Su
Byron_JMP
Re: exporting the surface profilers
try using the selection tool?  (keyboard shortcut s)
https://community.jmp.com/t5/JMP-On-Air/The-Tools-Menu/ta-p/257360257360
