fguerville
define reference value of a nominal variable
Hello
I'm using JMP Pro 12 and would like to know how to define the reference value of a nominal variable.
For example, in order to use this variable in a Cox model.
Without any defined reference for the nominal variable, JMP provides HR for each comparison between 2 groups, whereas i would like to compare each other group to the reference group only.
Thanks
Florent
ron_horne
Re: define reference value of a nominal variable
hi @fguerville,
i think what you are looking for comes from the times multiple category variables were introduced as a set of dummy variables. therefore, try the following:
https://community.jmp.com/t5/JMP-Academic-Knowledge-Base/Make-Indicator-Dummy-Variables/ta-p/22636
let us know if it helps,
Ron
ron_horne
hi @fguerville,
Ron
