Hi @joann , sorry to say but this is not the platform for full service, but we are happy if we can support you. So if you want to learn please see the online documentation on the functions used here.
E.g. loc gives you the index of a vector for certain values:
Loc Functions (jmp.com)
Please see below script for both scenarios. Scenario B is quite similar ...
If you want to have the exact table for scenario B as you described, you can delete the formula (that keeps the values then), and select the missing values in column "Formula B" and delete them.
BR
names default to here(1);
// create the example table
New Table( "20210404_user_web_booking_matrixexample",
Add Rows( 12 ),
Compress File When Saved( 1 ),
New Column( "userID",
Numeric,
"Continuous",
Format( "Best", 12 ),
Set Values(
[2523, 2523, 2523, 2523, 2523, 2523, 2540, 2540, 2540, 2540, 2540, 2540]
Set Display Width( 66 )
New Column( "action",
Character( 16 ),
"Nominal",
Set Values(
{"web", "web", "booking", "booking", "web", "booking", "web", "web",
"booking", "booking", "web", "booking"}
Set Display Width( 73 )
New Column( "date",
Numeric,
"Continuous",
Format( "y/m/d", 12 ),
Input Format( "y/m/d" ),
Set Values(
[3608409600, 3609273600, 3610310400, 3611260800, 3613852800, 3616531200,
3647462400, 3647548800, 3647635200, 3647721600, 3647808000, 3647894400]
Set Display Width( 92 )
New Column( "first web date to first booking date",
Numeric,
"Continuous",
Set Values( [22, 22, 22, 22, 22, 22, ., ., ., ., ., .] ),
Set Display Width( 150 )
New Column( "formula_A",
Numeric,
"Continuous",
Formula(
// convert columns to vectors
dat_vec = :date << get values;
web_vec = :action << get values;
user_vec = :userID << get values;
// get a vector with subscripts of current userID
user_index = user_vec == :userID[Row()];
// get a vctor with subscripts where action=web
web_index = Matrix(
Substitute( :action << get values, "web", 1, "booking", 0 )
// get a vector with dates for current userID and action=web
web_dat = dat_vec[Loc( user_index & web_index )];
// the same for booking (actually not web)
booking_dat = dat_vec[Loc( user_index & !web_index )];
// calculate minimum of both date vectors and subtract
(Minimum( booking_dat ) - Minimum( web_dat )) / (3600 * 24);
Set Display Width( 146 )
New Column( "formula_B",
Numeric,
"Continuous",
Formula(
web_index = Matrix(
// when current action is booking, then subtract minimum web date, otherwise keep empty, and divide seconds by seconds of day
If( :action == "booking", :date - Minimum( web_dat ), . ) / (3600 * 24);
Set Selected
Georg
