deer_dog
data from excluded rows are still showing on graph
I selected and then excluded certain rows to keep them out of the analysis. That worked for a one-way distribution. But when 'fitting y on x', I still see the points for rows that have been excluded (or at least I tried to exclude them). I know that because you see the row number when highlighting specific points in the figure. I assume the rows I don't want included were also included in the equation (I fit a polynomial to the points).
I have used JMP a lot and have not had this problem before (or at least I have not noticed it). What am I missing? I am using JMP 7
Thanks for the help!
p.s. I see another discussion that indicates that excluded data show up on bivariate plots (assume they are not considered in the stats). Is there a way to keep them from showing up?
p.s. ok, I can do this using 'hide row' but is that the best way? I don't recall using that in the past.
okay (2 hrs later) question answered, I see that is how it works - need to 'hide' the row. I always thought excluding the row was enough.
David_Burnham
The exclude row state excludes data points from an analysis - it does not exclude the appearance of a data point on a graph.  The hide row state removes data points from a graph (but not from an analysis).  So to achieve what you want you have to both exclude and hide the data point (personally I prefer to exclude the data point and change the marker colour).
Dave
-Dave
David_Burnham
Dave
-Dave
deer_dog
Thanks Dave!
