TonyS
data cleanup, merge data from 3 columns into one column
HI Newbie here, I need some help to merge the data from 3 columns into one column, the data were collected in different time and by different person, and in 3 columns, so there are some missing data, some matched, like this:
A  B  C
1  1
0      0
1      1
How do I merge the data in A, B, C columns into one column in JMP?
Thank you so much for helping!
Re: data cleanup, merge data from 3 columns into one column
The formula for a new column that contains the single matched value would be
substring( trim(:A || :B || :C), 1, 1 )
Concatenate the 3 columns together, and then take the first character
If you are sure you won't have any empty rows (or if you have empty row it will be coded as 0):
If(
	Contains(:A || :B || :C, "1"), "1",
	"0"
Also with JMP Missing is not same as "0". With the characters the Missing value would be empty string ("") and with numeric values it would be period (.) and sometimes this has to be taken into account.
Show(Ismissing(""));
Show(IsMissing(.));
6 REPLIES 6
How would you like to combine them? Sum of them? Concatenate them together? For example to sum them you could create new formula column with following formula:
Sum(:A, :B, :C)
To concatenate (character data), select all columns, right click on one of them and:
Or select all of them, Cols / Utilities / Combine Columns:
Are the columns numeric or character?
Given the above example, what is your expectation of what the final column will contain?
1
0
1
or
11
0 0
1 1
or
11
00
11
TonyS
Thanks txnelson and jthi, the columns are character, I need them to be either 1 or 0, the data in the 3 columns are either match or missing, so I just need to aggregate them together.
Much appreciated!!
If(
	"0"
Show(IsMissing(.));
TonyS
Thanks!!!
