jumboshrimps
custom expression Today() minus seven days in query builder
Attempting to obtain all releases by date (reldate) 7 days ago from ORACLE through ODBC Connection table.
Code below returns the attached error image:
SELECT DISTINCT t1.PIN, t1.PCP, t1.LASTNAME, t1.COMDATE,
 t1.RELDATE, t1.JLOCAT, t1.SEX, t1.RELTYPE,
 t1.RELAUTH, t1.RELCUST
FROM schema.table  t1
WHERE  (  (  ( t1.RELDATE >= (Today() - In Days( 7 ))  )
2nd question:
Once I get this query straight, does JMP have an automated macro function to run this  jmpquery every Monday morning at 3:00 am?   - I  also have the JMP addon for Excel 2010.
pmroz
Re: custom expression Today() minus seven days in query builder
You're missing two close parentheses.
WHERE  (  (  ( t1.RELDATE >= (Today() - In Days( 7 ))  ) ) )
If you have Oracle errors try executing the query in a SQL tool like PL/SQL Developer, Toad etc.
