pulong
create formula to generate columns of design matrix
I am a beginner to use JMP, and cannot find similar answers to my questions in JMP community. Suppose that I have a data table with several columns, and the user needs to select the column from the data table and then a design matrix will be generated according the selected column. The selected column and the design matrix will be created in a new data table. But this is not enough. If the user want to change the value in the selected column in the new data table, then the design matrix will be updated accordingly. My problems is that I cannot update the design matrix correctly with the code below:
// create a window to select column
// omit some code to create the window
CheckAndConvert = Expr(
selectedColumns = c << Get Items;
// If inputs are valid, we continue
If(N Items(selectedColumns) > 0,
win << Close Window;
A = Column(selectedColumns);
s = A << GetAsMatrix;   // extract the select column in s
// create the new data table "Design Matrix"
dt = New Table("Design Matrix");
dt << New Column("slice", Numeric, Values(s[0, 1]));  // copy s to the column "slice" in the new data table
// create corresponding columns of design matrix and adding them into the new data table
For( i=1, i<=Col Max(dt:slice), i++,
  dt << New Column("X"||Char(i), Numeric,
  After Last,
  Formula(
  If(dt:slice == i, 1,
  0
PS:  I can get the correct answer when run the code without change the value in the slice column, but I cannot update X columns if I change the value of slice. Note that the number of X columns is the maximum value in the slice column, which is not fixed with different values. In following pictures, I show the examples to select column 1 and column 2 in the test data.
Thanks in advance,
Pulong
11 REPLIES 11
Re: create formula to generate columns of design matrix
Please see Help > Scripting Index. Change the browser to show Functions. Then select the Matrix group of functions. You will find here several functions to make the model matrix (for terms) from the design matrix (factor levels).
My apologies. I read your request again and realized that none of the JSL functions will help in this case. They are intended to create the columns for the effects of categorical factors for the linear regression.
Here is a script that will take the matrix with the factor levels and create the matrix with a column for each term in a quadratic polynomial:
Names Default to Here( 1 );
x2fx = Function( { x }, { n factors, n treat, fx, f, f1, f2 },
	n factors = N Col( x );
	n treat = N Row( x );
	fx = J( n treat, 1, 1 );
	For( f = 1, f <= n factors, f++,
		fx ||= x[0,f];
	For( f1 = 1, f1 < n factors, f1++,
		For( f2 = f1+1, f2 <= n factors, f2++,
			fx ||= x[0,f1] :* x[0,f2];
		fx ||= x[0,f]^2;
	fx;
X = [1 10,
     2 20,
     3 10,
     4 20,
     5 15,
     6 15];
D = x2fx( X );
Show( D );
It is not that hard to make your own functions.
