gianpaolo
create a weight Column
Good morning.
using JSL code, starting from a column with GOOD / BAD rows, i would like to create a new WEIGHT COLUMN, where BAD =1 and GOOD = Ratio BAD/GOOD.
 There is JSL to do it quickly?
thanks in advance
Gianpaolo
Gianpaolo Polsinelli
Re: create a weight Column
Here are two similar solutions.
This one generates the new column in open JSL
// Create the sample data table
dt = New Table( "Good Bad Ratio",
	Add Rows( 14 ),
	New Column( "Good_Bad",
		Character,
		"Nominal",
		Set Values(
			{"GOOD", "BAD", "GOOD", "GOOD", "GOOD", "GOOD", "GOOD", "GOOD", "GOOD", "GOOD",
			"GOOD", "BAD", "BAD", "BAD"}
// Create the new column using a formula for the calculation
dt << New Column( "Weight",
	formula(
		If( Row() == 1,
			TheGoodCount = Col Number( If( :Good_Bad == "GOOD", 1, . ) );
			TheBadCount = Col Number( If( :Good_Bad == "BAD", 1, . ) );
			Ratio = TheBadCount / TheGoodCount;
		If(
			:Good_Bad == "GOOD", Ratio,
This version uses a column formula to create the values for the column Weight
	Add Rows( 14 ),
		Character,
		"Nominal",
		Set Values(
// Calculate the Ratio
TheGoodCount = Col Number( If( dt:Good_Bad == "GOOD", 1, . ) );
TheBadCount = Col Number( If( dt:Good_Bad == "BAD", 1, . ) );
// Add the new column and populate it
dt << New Column( "Weight" );
For Each Row(
	If(
		dt:Good_Bad == "GOOD", dt:Weight = Ratio,
		dt:Good_Bad == "BAD", dt:Weight = 1
uday_guntupalli
Level VIII
Can you kindly provide sample data of your column to understand what GOOD / BAD looks like ?
Best
Uday
gianpaolo
Split Weight Split where:
GOOD 0.4 BAD=1
BAD 1 GOOD = #BAD/#GOOD
GOOD 0.4 in this case 4/10 =0.4
GOOD 0.4
GOOD 0.4
GOOD 0.4
GOOD 0.4
GOOD 0.4
GOOD 0.4
GOOD 0.4
GOOD 0.4
BAD 1
BAD 1
BAD 1
	Add Rows( 14 ),
		Character,
		"Nominal",
		Set Values(
	formula(
		If( Row() == 1,
		If(
	Add Rows( 14 ),
		Character,
		"Nominal",
		Set Values(
For Each Row(
	If(
gianpaolo
Great Jim, Thanks very much.
i will adapt your code to my job
