Here are two similar solutions.
This one generates the new column in open JSL
// Create the sample data table
dt = New Table( "Good Bad Ratio",
	Add Rows( 14 ),
	New Column( "Good_Bad",
		Character,
		"Nominal",
		Set Values(
			{"GOOD", "BAD", "GOOD", "GOOD", "GOOD", "GOOD", "GOOD", "GOOD", "GOOD", "GOOD",
			"GOOD", "BAD", "BAD", "BAD"}
// Create the new column using a formula for the calculation
dt << New Column( "Weight",
	formula(
		If( Row() == 1,
			TheGoodCount = Col Number( If( :Good_Bad == "GOOD", 1, . ) );
			TheBadCount = Col Number( If( :Good_Bad == "BAD", 1, . ) );
			Ratio = TheBadCount / TheGoodCount;
		If(
			:Good_Bad == "GOOD", Ratio,
This version uses a column formula to create the values for the column Weight
	Add Rows( 14 ),
		Character,
		"Nominal",
		Set Values(
// Calculate the Ratio
TheGoodCount = Col Number( If( dt:Good_Bad == "GOOD", 1, . ) );
TheBadCount = Col Number( If( dt:Good_Bad == "BAD", 1, . ) );
// Add the new column and populate it
dt << New Column( "Weight" );
For Each Row(
	If(
		dt:Good_Bad == "GOOD", dt:Weight = Ratio,
		dt:Good_Bad == "BAD", dt:Weight = 1
