joann
count unique
Hi, I have a table with transaction data like the below.
transactionID, individualID, product
1, a, apple
2, a, orange
3, b, apple
4, b, banana
5, c, orange
I want to do in tabulate, not using script, to count how many unique individualID by product.
Does anyone know how to do this?
I can do summary table using individualID and product first, and then do a tabulate on it to get the uniqueID count by product, but this is 2 steps. Wondering is there a way we can do it in tabulate just one step cause i constantly need to do this for many different groups?
Thank you!
15 REPLIES 15
ih
Super User (Alumni) ih
Re: count unique
Yet another option: you could also make a summary column right in the tabulate function:
Names default to here(1);
dt = Open("$Sample_data/big class.jmp");
dt << Tabulate(
	Show Control Panel( 0 ),
	Add Table(
		Column Table(
			Analysis Columns(
				Transform Column( "Age Count", Formula( Col Sum( 1, :age ) ) )
			Statistics( Mean )
		Row Table( Grouping Columns( :age ) )
hogi
Level XIII
Re: count unique
Is there a shortcut for N categories or count unique in the right click New Formula Column menu?
I guess there is one (as it is needed so often), but I couldn't find it - what's the name?
NB: not all of the replies here referred to N categories or count unique  - some are more like N rows per unique entry.
Re: count unique
There is not a right click solution to this issue, as far as I know.  The old school way that I approach this is:
Summarize( bygroup = by( :age ) );
UniqueCount = N Items( bygroup );
hogi
Level XIII
Re: count unique
Thanks Jim :)
For my application I need a function which uses the Group By option of the right click New formula Column menu to calculate and distribute the respective values - similar to Col Number (Count), but just counting unique/distinct entries.
There is nothing like
N categories(column, bygroups)
- or a an option just count unique values for the Col Number function?
Big-Class application case:
A user want to calculate the percentage of age groups, with mean height > 60, separately for male and female. Then  N categories could be a nice way to do this:
PercentTallAgeGroups = N Categories(if(Col Mean(:height,:age, :sex) > 60,:age, .), :sex) / N Categories(:age, :sex)*100
More reasonable application cases:
- ratio of defects per measured wafer for several lots (for a data set with chip-fine data)
- ratio of cities with >0.1% Covid mortality for several countries
Workaround:
Generate a Summary Table with the needed by groups and merge it back into the main table.
hogi
Level XIII
Re: count unique
If other users are interested as well to have N Categories not just in the Tables/Summary Platform, but also via JSL ...
  - here is the wish:
new JSL function: Col N Categories
hogi
Level XIII
Re: count unique
