qy6b0
control chart with multiple items how to save summaries in one table
I have a control chart (cc) window with multiple items (i.e. each item has a control chart). In jsl, when I use cc<< Save Summaries, it pops up a summary table for each item. How can I save all summaries in one table with item name identified? Thank you.
Peter_Bartell
Level VIII
Re: control chart with multiple items how to save summaries in one table
As a suggestion, why not just use the hot spot drop down option from the control chart window for Save Summaries? This creates a single JMP data table with column identified quantities for various summary measures.
The default action with ,<< Save Summaries is to create a single table for all charts defined for the platform.  The example below will produce an example of the combined Summary Table.
dt = Open( "$SAMPLE_DATA/Quality Control/Airport.jmp" );
// Add a column so there is a second charting column
dt<< new column("Random",formula(Random Uniform()));
obj = Control Chart(
       Sample Size( :Day ),
       KSigma( 3 ),
       Chart Col( :Delay, XBar, R ),
       Chart Col( :Random, XBar, R )
obj << Save Summaries;
Could you clarify your issue?
vheber
How could the same (save all summaries in one table with item name identified) be done if a By-variable is used in the control chart?
Like in this example that creates a chart for ByVar=1 and ByVar=2:
dt<< new column("ByVar", Character, formula(left(:Day,1)));
  KSigma( 3 ),
  Chart Col( :Delay, XBar ),
  By(:ByVar)
ian_jmp
Level X
If you use the tooltip in the editor, you will see that (when using a 'By' variable), obj is a list. So you could try something like:
dt<< new column("By",formula(Random Integer(1, 2)));
       KSigma( 3 ),
       Chart Col( :Random, XBar, R ),
       By(:By)
For(b=1, b<=NItems(obj), b++, obj[b] << Save Summaries);
Then you have to consolidate the resulting tables of course.
Phil_Brown
qy6b0​
veronica.a.heber​
You could try the following:
dt << New Column( "ByVar", Character, formula( Left( :Day, 1 ) ) );
obj = Control Chart( Sample Size( :Day ), KSigma( 3 ), Chart Col( :Delay, XBar ), By( :ByVar ) );
Current Data Table( dt );
Summarize( byVals = By( :ByVar ) );
res = obj << SaveSummaries;
If( Is List( res ),
finalTable = res[1] << concatenate( res[2 :: N Items( res )], create source column, outputTableName( "Saved Summaries" ) );
Try(
col = Column( finalTable, "Source Table" );
col << set name( dt:ByVar << get name );
For( i = 1, i <= N Items( res ), i++,
col[finalTable << get rows where( Column( dt:ByVar << get name )[] == (res << get name) )] = byVals;
Close( res, NoSave );
finalTable = res
PDB
