chandankishor66
conditional match with two columns
Hi JMP users
How to write a script to print a value from column:EtOH % form maximum index of : fermentation Age .
For example: if the maximum fermentation Age for Batch 03-05-2022 is 68 then the EtOH % value (13.45) should be picked and printed to the output column.
Attached a JMP table here.
Looking forward for your suggestion
Regards
Re: conditional match with two columns
Here are 2 similar approaches to solve your issue.
dt = Current Data Table();
dt << New Column( "Output 2",
	formula(
		theMax = Col Maximum( :EtOH %, :Batch );
		If( theMax == :EtOH %,
			:EtOH %,
dt << New Column( "Output 3" );
for each row(
			:Output3 = :EtOH %,
			:Output3 = .
	formula(
			:EtOH %,
for each row(
			:Output3 = :EtOH %,
			:Output3 = .
chandankishor66
Thank you, Jim.
