jsolo01
concatenating cells
I am trying to convert rows grouped by a composite variable into a concatenated cell sepearated by a space based on the grouping variable.  Example:
into:
The code below creates a grouping column and a "N rows" column but i cant get the contents of the cells concatenated.
dt_summary = dt << Summary(
Group( :Column B ),
Statistics(
Concatenate( :Column A, " " )
mmarchandFSLR
Re: concatenating cells
You could do it this way.  This accounts for the possibility of duplicates in Column A and only lists each item once.
Summarize( dt, cats = By( :Column B ) );
dt_summary = New Table( "Summary", New Column( "Category", Character, "Nominal" ), New Column( "Items", Character, "Nominal" ) );
For Each( {v, i}, cats,
	dt_summary << Add Rows(
		{:Category = v, :Items = Concat Items( Associative Array( dt:Column A[Where( dt, :Column B == v )] ) << Get Keys, " " )}
mmarchandFSLR
I like doing this with SQL Query from JMP table
dt = open("$SAMPLE_DATA/Big Class.jmp");
dt_concat = Query(
	Table(dt, "t1"),
SELECT age, GROUP_CONCAT(sex) as g,
count(*) as n
FROM t1
GROUP BY age
You can also ignore duplicates by adding DISTINCT to the group concat
dt_concat = Query(
	Table(dt, "t1"),
SELECT age, GROUP_CONCAT(DISTINCT sex) as g,
count(*) as n
FROM t1
GROUP BY age
jsolo01
thanks for the reply.  havent done a SQL query but will give it a try.
There is also a wish list item Add Listagg/Concatenate/GROUP_CONCAT to Summary platform
