BookmarkSubscribeRSS Feed
SoilStats
Community Trekker
colorblind safe palette, JMP 13
Which of the palettes included in JMP 13 are colorblind safe?
XanGregg
Re: colorblind safe palette, JMP 13
For categorical colors, the "universal" color theme supports all color deficiencies and is from "Barrier-free presentation that is friendly to colorblind people".
For continuous colors, the sequential themes are good because they vary in brightness along the scale.
9 REPLIES 9
Kevin_Anderson
Community Trekker
Hi, SoilStats!
I think your best bet is to go to ColorBrewer and find the colorblind-safe palette to accomplish your communication goal.  You can specify number of classes, the nature of your data, and color schemes.
JMP, and especially JSL, allows specification of RGB colors in all platforms.
Good luck!
Byron_JMP
The JMP "Universal" color theme works well. I use it as my defalut most of the time.
If you want to manually add a color theme. Paste something like this into your preferences.
Add Color Theme(
	{"Red Yellow Blue", 4099, {{165, 0, 38}, {215, 48, 39}, {244, 109, 67}, {253, 174, 97}, {254, 224, 144}, {255, 255, 191
	}, {224, 243, 248}, {171, 217, 233}, {116, 173, 209}, {69, 117, 180}, {49, 54, 149}}}
Note: From a script window, run Get Preferences();  Take what gets returned to the log, and paste it into a new script window. Make the first line say Set Preferences(...  rather than just Preferences(...
Insert this bit of code into the preferences script and then run it.
Now you should find this color theme available in your Graph preferences.
JMP Systems Engineer, Pharm and BioPharm Sciences
SoilStats_
Community Trekker
Add Color Theme(
What does the "4099" stand for? I am trying to import "Cividis" color palette into JMP and don't know what to put for it.
SoilStats_
Community Trekker
.txt of Cividis attached
Byron_JMP
I got this to work. The 4 digit number is a "flag", but I'm not sure what that means, or where it comes from.
Add Color Theme(
		{"Civitas", 2051, {{0, 32, 76}, {0, 32, 78}, {0, 33, 80}, {0, 34, 81}, {0,
		35, 83}, {0, 35, 85}, {0, 36, 86}, {0, 37, 88}, {0, 38, 90}, {0, 38, 91}, {0,
		39, 93}, {0, 40, 95}, {0, 40, 97}, {0, 41, 99}, {0, 42, 100}, {0, 42, 102},
		{0, 43, 104}, {0, 44, 106}, {0, 45, 108}, {0, 45, 109}, {0, 46, 110}, {0, 46,
		111}, {0, 47, 111}, {0, 47, 111}, {0, 48, 111}, {0, 49, 111}, {0, 49, 111},
		{0, 50, 110}, {0, 51, 110}, {0, 52, 110}, {0, 52, 110}, {1, 53, 110}, {6, 54,
		110}, {10, 55, 109}, {14, 55, 109}, {18, 56, 109}, {21, 57, 109}, {23, 57,
		109}, {26, 58, 108}, {28, 59, 108}, {30, 60, 108}, {32, 60, 108}, {34, 61,
		108}, {36, 62, 108}, {38, 62, 108}, {39, 63, 108}, {41, 64, 107}, {43, 65,
		107}, {44, 65, 107}, {46, 66, 107}, {47, 67, 107}, {49, 68, 107}, {50, 68,
		107}, {51, 69, 107}, {53, 70, 107}, {54, 70, 107}, {55, 71, 107}, {56, 72,
		107}, {58, 73, 107}, {59, 73, 107}, {60, 74, 107}, {61, 75, 107}, {62, 75,
		107}, {64, 76, 107}, {65, 77, 107}, {66, 78, 107}, {67, 78, 107}, {68, 79,
		107}, {69, 80, 107}, {70, 80, 107}, {71, 81, 107}, {72, 82, 107}, {73, 83,
		107}, {74, 83, 107}, {75, 84, 107}, {76, 85, 107}, {77, 85, 107}, {78, 86,
		107}, {79, 87, 108}, {80, 88, 108}, {81, 88, 108}, {82, 89, 108}, {83, 90,
		108}, {84, 90, 108}, {85, 91, 108}, {86, 92, 108}, {87, 93, 109}, {88, 93,
		109}, {89, 94, 109}, {90, 95, 109}, {91, 95, 109}, {92, 96, 109}, {93, 97,
		110}, {94, 98, 110}, {95, 98, 110}, {95, 99, 110}, {96, 100, 110}, {97, 101,
		111}, {98, 101, 111}, {99, 102, 111}, {100, 103, 111}, {101, 103, 111}, {102,
		104, 112}, {103, 105, 112}, {104, 106, 112}, {104, 106, 112}, {105, 107, 113
		}, {106, 108, 113}, {107, 109, 113}, {108, 109, 114}, {109, 110, 114}, {110,
		111, 114}, {111, 111, 114}, {111, 112, 115}, {112, 113, 115}, {113, 114, 115
		}, {114, 114, 116}, {115, 115, 116}, {116, 116, 117}, {117, 117, 117}, {117,
		117, 117}, {118, 118, 118}, {119, 119, 118}, {120, 120, 118}, {121, 120, 119
		}, {122, 121, 119}, {123, 122, 119}, {123, 123, 120}, {124, 123, 120}, {125,
		124, 120}, {126, 125, 120}, {127, 126, 120}, {128, 126, 120}, {129, 127, 120
		}, {130, 128, 120}, {131, 129, 120}, {132, 129, 120}, {133, 130, 120}, {134,
		131, 120}, {135, 132, 120}, {136, 133, 120}, {137, 133, 120}, {138, 134, 120
		}, {139, 135, 120}, {140, 136, 120}, {141, 136, 120}, {142, 137, 120}, {143,
		138, 120}, {144, 139, 120}, {145, 140, 120}, {146, 140, 120}, {147, 141, 120
		}, {148, 142, 120}, {149, 143, 120}, {150, 143, 119}, {151, 144, 119}, {152,
		145, 119}, {153, 146, 119}, {154, 147, 119}, {155, 147, 119}, {156, 148, 119
		}, {157, 149, 119}, {158, 150, 118}, {159, 151, 118}, {160, 152, 118}, {161,
		152, 118}, {162, 153, 118}, {163, 154, 117}, {164, 155, 117}, {165, 156, 117
		}, {166, 156, 117}, {167, 157, 117}, {168, 158, 116}, {169, 159, 116}, {170,
		160, 116}, {171, 161, 116}, {172, 161, 115}, {173, 162, 115}, {174, 163, 115
		}, {175, 164, 115}, {176, 165, 114}, {177, 166, 114}, {178, 166, 114}, {180,
		167, 113}, {181, 168, 113}, {182, 169, 113}, {183, 170, 112}, {184, 171, 112
		}, {185, 171, 112}, {186, 172, 111}, {187, 173, 111}, {188, 174, 110}, {189,
		175, 110}, {190, 176, 110}, {191, 177, 109}, {192, 177, 109}, {193, 178, 108
		}, {194, 179, 108}, {196, 180, 108}, {197, 181, 107}, {198, 182, 107}, {199,
		183, 106}, {200, 184, 106}, {201, 184, 105}, {202, 185, 105}, {203, 186, 104
		}, {204, 187, 104}, {205, 188, 103}, {206, 189, 103}, {207, 190, 102}, {209,
		191, 102}, {210, 192, 101}, {211, 192, 101}, {212, 193, 100}, {213, 194, 99},
		{214, 195, 99}, {215, 196, 98}, {216, 197, 98}, {217, 198, 97}, {219, 199,
		96}, {220, 200, 96}, {221, 201, 95}, {222, 202, 94}, {223, 203, 93}, {224,
		203, 93}, {225, 204, 92}, {227, 205, 91}, {228, 206, 91}, {229, 207, 90},
		{230, 208, 89}, {231, 209, 88}, {232, 210, 87}, {233, 211, 86}, {235, 212,
		86}, {236, 213, 85}, {237, 214, 84}, {238, 215, 83}, {239, 216, 82}, {240,
		217, 81}, {242, 218, 80}, {243, 219, 79}, {244, 220, 78}, {245, 221, 77},
		{246, 222, 76}, {247, 223, 75}, {249, 224, 73}, {250, 224, 72}, {251, 225,
		71}, {252, 226, 70}, {253, 227, 69}, {255, 228, 67}, {255, 229, 66}, {255,
		230, 66}, {255, 231, 67}, {255, 232, 68}, {255, 233, 69}}}
its a nice color theme
SoilStats_
Community Trekker
Thanks! I was just posting one as well :)
SoilStats_
Community Trekker
Got it to work!
Add Color Theme(
	{"Cividis", {{0, 32, 76}, {0, 32, 78}, {0, 33, 80}, {0, 34, 81}, {0, 35, 83}, {0, 35, 85}, {0, 36, 86}, {0,
	37, 88}, {0, 38, 90}, {0, 38, 91}, {0, 39, 93}, {0, 40, 95}, {0, 40, 97}, {0, 41, 99}, {0, 42, 100}, {0, 42,
	102}, {0, 43, 104}, {0, 44, 106}, {0, 45, 108}, {0, 45, 109}, {0, 46, 110}, {0, 46, 111}, {0, 47, 111}, {0,
	47, 111}, {0, 48, 111}, {0, 49, 111}, {0, 49, 111}, {0, 50, 110}, {0, 51, 110}, {0, 52, 110}, {0, 52, 110},
	{1, 53, 110}, {6, 54, 110}, {10, 55, 109}, {14, 55, 109}, {18, 56, 109}, {21, 57, 109}, {23, 57, 109}, {26,
	58, 108}, {28, 59, 108}, {30, 60, 108}, {32, 60, 108}, {34, 61, 108}, {36, 62, 108}, {38, 62, 108}, {39, 63,
	108}, {41, 64, 107}, {43, 65, 107}, {44, 65, 107}, {46, 66, 107}, {47, 67, 107}, {49, 68, 107}, {50, 68, 107},
	{51, 69, 107}, {53, 70, 107}, {54, 70, 107}, {55, 71, 107}, {56, 72, 107}, {58, 73, 107}, {59, 73, 107}, {60,
	74, 107}, {61, 75, 107}, {62, 75, 107}, {64, 76, 107}, {65, 77, 107}, {66, 78, 107}, {67, 78, 107}, {68, 79,
	107}, {69, 80, 107}, {70, 80, 107}, {71, 81, 107}, {72, 82, 107}, {73, 83, 107}, {74, 83, 107}, {75, 84, 107},
	{76, 85, 107}, {77, 85, 107}, {78, 86, 107}, {79, 87, 108}, {80, 88, 108}, {81, 88, 108}, {82, 89, 108}, {83,
	90, 108}, {84, 90, 108}, {85, 91, 108}, {86, 92, 108}, {87, 93, 109}, {88, 93, 109}, {89, 94, 109}, {90, 95,
	109}, {91, 95, 109}, {92, 96, 109}, {93, 97, 110}, {94, 98, 110}, {95, 98, 110}, {95, 99, 110}, {96, 100, 110
	}, {97, 101, 111}, {98, 101, 111}, {99, 102, 111}, {100, 103, 111}, {101, 103, 111}, {102, 104, 112}, {103,
	105, 112}, {104, 106, 112}, {104, 106, 112}, {105, 107, 113}, {106, 108, 113}, {107, 109, 113}, {108, 109,
	114}, {109, 110, 114}, {110, 111, 114}, {111, 111, 114}, {111, 112, 115}, {112, 113, 115}, {113, 114, 115},
	{114, 114, 116}, {115, 115, 116}, {116, 116, 117}, {117, 117, 117}, {117, 117, 117}, {118, 118, 118}, {119,
	119, 118}, {120, 120, 118}, {121, 120, 119}, {122, 121, 119}, {123, 122, 119}, {123, 123, 120}, {124, 123,
	120}, {125, 124, 120}, {126, 125, 120}, {127, 126, 120}, {128, 126, 120}, {129, 127, 120}, {130, 128, 120},
	{131, 129, 120}, {132, 129, 120}, {133, 130, 120}, {134, 131, 120}, {135, 132, 120}, {136, 133, 120}, {137,
	133, 120}, {138, 134, 120}, {139, 135, 120}, {140, 136, 120}, {141, 136, 120}, {142, 137, 120}, {143, 138,
	120}, {144, 139, 120}, {145, 140, 120}, {146, 140, 120}, {147, 141, 120}, {148, 142, 120}, {149, 143, 120},
	{150, 143, 119}, {151, 144, 119}, {152, 145, 119}, {153, 146, 119}, {154, 147, 119}, {155, 147, 119}, {156,
	148, 119}, {157, 149, 119}, {158, 150, 118}, {159, 151, 118}, {160, 152, 118}, {161, 152, 118}, {162, 153,
	118}, {163, 154, 117}, {164, 155, 117}, {165, 156, 117}, {166, 156, 117}, {167, 157, 117}, {168, 158, 116},
	{169, 159, 116}, {170, 160, 116}, {171, 161, 116}, {172, 161, 115}, {173, 162, 115}, {174, 163, 115}, {175,
	164, 115}, {176, 165, 114}, {177, 166, 114}, {178, 166, 114}, {180, 167, 113}, {181, 168, 113}, {182, 169,
	113}, {183, 170, 112}, {184, 171, 112}, {185, 171, 112}, {186, 172, 111}, {187, 173, 111}, {188, 174, 110},
	{189, 175, 110}, {190, 176, 110}, {191, 177, 109}, {192, 177, 109}, {193, 178, 108}, {194, 179, 108}, {196,
	180, 108}, {197, 181, 107}, {198, 182, 107}, {199, 183, 106}, {200, 184, 106}, {201, 184, 105}, {202, 185,
	105}, {203, 186, 104}, {204, 187, 104}, {205, 188, 103}, {206, 189, 103}, {207, 190, 102}, {209, 191, 102},
	{210, 192, 101}, {211, 192, 101}, {212, 193, 100}, {213, 194, 99}, {214, 195, 99}, {215, 196, 98}, {216, 197,
	98}, {217, 198, 97}, {219, 199, 96}, {220, 200, 96}, {221, 201, 95}, {222, 202, 94}, {223, 203, 93}, {224,
	203, 93}, {225, 204, 92}, {227, 205, 91}, {228, 206, 91}, {229, 207, 90}, {230, 208, 89}, {231, 209, 88},
	{232, 210, 87}, {233, 211, 86}, {235, 212, 86}, {236, 213, 85}, {237, 214, 84}, {238, 215, 83}, {239, 216, 82
	}, {240, 217, 81}, {242, 218, 80}, {243, 219, 79}, {244, 220, 78}, {245, 221, 77}, {246, 222, 76}, {247, 223,
	75}, {249, 224, 73}, {250, 224, 72}, {251, 225, 71}, {252, 226, 70}, {253, 227, 69}, {255, 228, 67}, {255,
	229, 66}, {255, 230, 66}, {255, 231, 67}, {255, 232, 68}, {255, 233, 69}}}
Byron_JMP
I like it!
This is a great theme, I think is my new default.
Thanks for posting it.
-B
XanGregg
