Greeny
changing line width in fit curve
Does anyone know how to change the default line width/thickness of the curve after fitting a model under "Fit Curve"? The default line width is too thin and doesn't appear well in PowerPoint.
Thanks in advance.
hogi
Level XIII
Re: changing line width in fit curve
Oh, that's right. The curve looks very elegant, but thin.
Maybe add a setting in the preferences?
If you post a wish in the wish list, I will give a Kudo :)
Unfortunately, the script is blocked and cannot be edited.
A kind of workaround:
 You could copy the script and increase the pen size:
(view in My Videos)
hogi
Level XIII
(view in My Videos)
Greeny
Thanks so much for taking the time to post this solution with the excellent video, especially on a Saturday morning. It worked perfectly. I spent a lot of time on this late last night because the default line width and color (light green) was not visible in PPT (when surrounded by data points). You made my day! Thanks again!
