robust1972
can we color the cells in jmp table as we do in excel? I mean really give colors to the part of table/cells interested
can we color the cells in jmp table as we do in excel? I mean really give colors to the part of table/cells interested?
I tried below jsl but it only works when you plot the data in graphs but not in the table itself?
Thanks in advance!
Evan
dt=Data Table( "Bin Wafer Map" );
For(i=4, i<=N col(dt),i++,
dt:i << Set Property(
"Value Colors",
{1=Green,3 = Red, 4 = Yellow,5=orange, 6 = Magenta, 7 =Blue,8 = Cyan,9=BlueCyan}
12 REPLIES 12
Von_Andre
Re: can we color the cells in jmp table as we do in excel? I mean really give colors to the part of
Hi! Found this topic is very helpful on my color cell function. However i have some concern. By using same table I only want to color cell values from columns 1 ~8 which contains > 0. Below code works on column 1 but I want to loop it through other columns 2~7. Can you help me on this? Thanks!
dt = Data Table( "Bin Wafer Map" );
For( i = 1, i <= N Row( dt ), i++,
If( Column( dt, "1" )[i] > 0, Column( dt, "1" ) << Color Cells( 4, {i} ),
ian_jmp
Level X
I guess you need another loop to take care of the columns. Something like:
// Loop over columns . . .
For(c = 1, c<=8, c++,
	// Loop over rows . . .
		If( Column( dt, c )[i] > 0,
			Column( dt, c ) << Color Cells( 4, {i} ),
Von_Andre
Thanks a lot Ian! Nice work!
