Dib-Dey
can't find the file path generated by Set Path Variable
I have a repo in following structure:
 repo:
        name.jsl
       dir_A
               root.jsl
       dir_B
              example.jsl
root.jsl
As repo is cloned for each user in different location. I have generated a a script which calls Python and always find the absolute path of the repo and set it as root.
cur_dir = Substr( Get Default Directory(), 2, 999 );
cur_dir = Substitute( cur_dir, "/", "\" );
show(cur_dir);
_path_script = cur_dir || "find_home_directory.py";
show(_path_script);
home_dir = RunProgram(
					executable( "python" ),
					options( _path_script),
					readfunction( "text" )
Set Path Variable( "root", home_dir );
Get Path Variable("root");
example.jsl
Include("../dir_A/root.jsl");
_var = "$root/name.jsl"
I checked and found the root is setup correctly and pointing to right directory.
I'm getting error for _var. Error with file: Path is invalid:
Byron_JMP
Re: can't find the file path generated by Set Path Variable
try.
get path variable("$root");
in your example
Get Path Variable("root");_var = "$root/name.jsl"
JMP is trying to evaluate _var="$root/name.jsl"
 I don't think the first char of the var name can be a special character or number.
