LogitPorcupine1
can i pin a ruler measurement to a graph in JMP
i was wondering, i often use the ruler function in graph builder to measure elements on a graph.  is there a way to pin that measurement to the graph itself? i can't seem to figure out a way to do it,
thanks!
Re: can i pin a ruler measurement to a graph in JMP
How about the following procedure if you are using Windows OS (unfortunately, the ruler disappears when you save a script)?
  1. Drag the ruler.
  2. Then, while holding down the left mouse button, right click.
  3. Now left-click on the window title (at the top of the window).
In my case, the menu should disappear, but the ruler stays.
