LogitPorcupine1
can i move the 5 number summary away from the top of my graphs?
hello,
i am making graphs with box plots and i want to display the 5 number summary on the graph.  the problem is that the 5 number summary always displays at the top of the graph, and it sometimes obscures the box plots,
is there a way to change the location of the 5 number summary so it doesn't interfere with the graph???
ron_horne
Re: can i move the 5 number summary away from the top of my graphs?
Hi @LogitPorcupine1 ,
The fastest way of doing so would be to modify the scale of the Y axis to make room for both.
otherwise, someone else may have a fundamental solution.
LogitPorcupine1
thanks you,
but yeah, i was hoping for a way where i didn't have to expand the y-scale
ron_horne
@LogitPorcupine1
if there is no way to access the 5 numbers in the graph and modify them i  think it would be better to run somthing like this:
Open( "$SAMPLE_DATA/Big Class.jmp" );
New Window( "Box plots - Height by Age",
	V List Box(
		Graph Builder(
			Size( 567, 640 ),
			Show Control Panel( 0 ),
			Fit to Window( "Off" ),
			Variables( X( :age ), Y( :height ) ),
			Elements( Box Plot( X, Y, Legend( 4 ) ) )
		Tabulate(
			Add Table(
				Column Table( Grouping Columns( :age ), Analysis Columns( :height ) ),
				Row Table( Statistics( Max, Quantiles( 75 ), Median, Quantiles( 25 ), Min ) )
you can modify it to fit your needs and save it as an add in for future use.
I didnt manage to access the 5 numbers from the properties if anyone knows how this may be the key to the solution
Joseph_Reese
In the past I have added 5 separate Caption Box elements to the graph, each listing one component of the 5 number summary. Those Caption Box elements give you a bit more control on where you want the information displayed. Always a good idea to make an addition to the JMP Wish List if there is functionality you are interested in. Thanks!
