Boaz
calculation using data from 2 tables
Hi all,
wandering if you can help...
I'm trying to create new columns in a table from a calculation of a transposed summary but I keep getting errors
with defining some constants from the table.
any idea what I'm doing wrong?
src_tran = src_sum << Transpose(
		Label( :Label )
Current Data Table( src_tran );
src_tran << new column("N", Formula(If( Substr( :Label, 0, 1 ) == "M",
	Substr( Substr( :Label, 6 ), 0, Length( :Label ) - 6 ),
	Substr( Substr( :Label, 9 ), 0, Length( :Label ) - 9 )
g = (Col Number( :Label) -2 );
for( i = 3, i = g, i++,
a = Char(N[i]) || "_Cv";
d =  Char(N[i]);
b = as column(Row 1)[i];
c = as column(Row 1)[i+1969];
Current Data Table( src );
src << new column( a, Numeric, continuous,
Formula( (b - :d) / (nsigma*c))); );
Log shows:
Column SEBV-D_CLK_A Cluster Size RsltF32_Pln00 (365) -1::21205_Cv Formula Interrupted Name Unresolved: d at row 1 in access or evaluation of 'd' , :d/*###*/ Formula evaluation errors have been ignored Name Unresolved: N in access or evaluation of 'N' , :N/*###*/
Re: calculation using data from 2 tables
It appears that you have several scoping and syntax issues, however, it is difficult to precisely guide you without seeing what the data table you are transforming contains.  Could you please attach a sample of what that table looks like?
ac7872
It seems you don't have a column name "d" for the Formula to work.
Try
src << new column( a, Numeric, continuous, Formula( (b - :Name( d ) ) / (nsigma*c)));
If that does not work you can try to create the line of code as text and parse it for each loop interaction.
