Thaelina
calculate odds ratios for several predictors
My data consists of two predictors, one with 3 responses (time at exposure) and 1 with two responses(gender.
I can do a log reg just fine and I cross my two variables, but I'm not sure how to interpret my OR's, .
I want to know: OR for early exposed females. How do I get that? Is that already in the table, or do I need multiply the OR for females with the OR for early exposed?
And if it's already in the table, how do I get early exposed males?
I've talked with my advisor and he insists that nominal is the way to go, so that's what I have done
dale_lehman
Re: calculate odds ratios for several predictors
You are correct - it appears that JMP does not provide odds ratios for the interactions.  Further, it seems to be somewhat complex to calculate them, but it can be done.  I found the following to provide some detail:
http://www.ats.ucla.edu/stat/stata/seminars/interaction_sem/interaction_sem.htm
Also, the early slides in
http://www.cantab.net/users/filimon/cursoFCDEF/will/logistic_interact.pdf
appear to show what to do.
dale_lehman
I might be wrong, but is sounds like you should include as a predictor the cross between time and gender.  It will have its own odds ratios which is what you are looking for.  It is entirely possible that you might be able to derive that from the odds ratios for the two predictors alone (although I doubt it), but I'm not smart enough to know how to do that.
Thaelina
But I think I already did that? I have 3 model effects: Gender, Exposure status and gender*exposure status, and I don't get any ORs for that. I get parameter estimates and effect likelihood ratio for it though, that's why I thought I might be able to calculate it. It might also be a part of the given OR's I just can't figure it out.
This is the OR output, but where is female-late neutering against unaltered?
Level1/Level2Odds RatioProb>ChisqLower 95%Upper 95%
Late neuteringEarly neutering2.85591490.19240.589562313.834415
UnalteredEarly neutering1.22802270.74890.34906454.3202328
UnalteredLate neutering0.42999270.12030.14826361.2470607
Early neuteringLate neutering0.35015050.19240.07228351.6961735
Early neuteringUnaltered0.81431720.74890.2314692.8648004
Late neuteringUnaltered2.32562070.12030.80188566.744742
Odds Ratios for Gender
MaleFemale1.15815070.7890.39506573.3951648
FemaleMale0.86344550.7890.29453652.5312246
dale_lehman
Thaelina
Oh dear,
Well, thank you so much for those links, they're exactly what I need!
