Created:
May 20, 2021 12:27 PM
| Last Modified: Jun 11, 2023 4:14 AM(2028 views)
I have created static bubble plots for my data (study habits (Y axis) ranked (X axis) by students at the beginning and end of the semester (two plots)) and would like to label each bubble with the % of respondents (which is also the determinant of the size of the bubble). When I choose 'label' it defaults to the rank.
Hi, In your table, select the "% of Respondents" column and set it as Label (Right Click on header > Label / Unlabel), then go to your Bubble plot, turn off the labels and turn these on again. Best, TS
Thierry R. Sornasse
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '387257' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '387257') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '387257') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
