boostrapping for regression
Why does my bootstapping option not appear?
When I go to the fit model and have my meditation entered for regression analysis. When I check the parameter estimate, it does not give me an option for bootstrapping?
Help :)
SDF1
Re: boostrapping for regression
Hi @SeasonalShark96 ,
  That is strange that you don't have the Bootstrap or Simulate option. I'm guessing you're running JMP Pro and don't have multiple JMP versions (regular vs Pro) installed on your computer, correct?
 Something to make sure is that you have to right click on the statistic of interest and not the name of the parameter. For example, if you click on the parameter name ARC_X instead of the value of the estimate, you will not have the option to Bootstrap or Simulate. Could that be what's going on?
Hope this helps!,
DS
Nope still doesnt show up. Im using Mac and it worked before but I recently had to buy a new laptop so I reinstalled the jmp software...
SDF1
  My only guess would be that you don't have Pro installed, or that you have a license only for standard JMP.
  Can you put in a tech support ticket?
Good luck!,
DS
