gpilgrim
blob to data table
I have a blob, output from runprogram.  The blob looks like this
blb = Char To Blob ("col1,col2~0D~0D~0AA,C~0D~0D~0AB,D~0D~0D~0A", "ascii~hex")
I'd like to convert it to a data table.
This post indicates that Open() can open a blob, but
Open(blb)
does not work.
"Cannot open tale in access or evaluation of 'Open', Open/*###*/(blb)".
RunProgram can also return text, but then I need to convert a string to a data table, which seems fussy.
I'd like a scripting solution please, JMP v 15
Re: blob to data table
I have unarchived that post .
6 REPLIES 6
The Open() function works with files. The argument should be a file path. You have to stream the blog out first before you can open it. The discussion you cited uses Open() after a string is saved to a text file in a format similar to CSV. Craig suggests that Open() works with a blog as the argument instead of a path, but that is not explicitly tried.
Have you confirmed that the Char to Blob() function returns a valid blob?
Sorry - I am confused now!
gpilgrim
1) Char to Blob and its contents are what is returned by call to RunProgram
2) The actual output of the non-JMP program called in RunProgram is a csv file written to stdout.  I do not want to write the csv to a file location, so no file path
3) From the linked discussion it seems like using a blob instead of a path in Open was tried here, but that post is no longer available for some reason
gpilgrim
Thank you!
The key, as shown in the unarchived post you shared is
Open(blb, "text")
That solves my problem
ErraticAttack
I'm not sure how you're getting your blob or whether it's correctly formatted, but here is an example where I save a data table as a standard JMP file, then read it in as a blob.  Once I have that blob it's quite simple to convert it into a table (last line)
Names Default to Here( 1 );
dt << Save( "$TEMP\BLOB_TEST.jmp" );
Close( dt, No Save );
file = Load Text File( "$TEMP\BLOB_TEST.jmp", "Blob" );
table = Open( file, JMP );
Jordan
gpilgrim
The blob comes from RunProgram, with ReadFunction set to "blob".  The program being called in RunProgram writes a csv to stdout, where it's picked up by RunProgram and returned as a blob.  I can also have it returned as text, but like I said, parsing text into a data frame seems fussy.  If I'm wrong about that please let me know.
What I don't want to do is have the non-JMP program write an actual csv file and then open that, because juggling temporary csv files will not work in my application
