fr2007
adding two columns and doing sum in JSL
i have an excel sheet with the following rows and columns:
NumbersRed BlueBlackGreen
70061012
70091234
70121456
70151678
701818910
70211101112
70241121314
70271141516
70301161718
70331181920
70361202122
70391222324
now i need to add two columns namely red+blue and black+green  and count the total of red+blue for each number and place in the resultant column..and same with the second column too..my result should be
NumbersRed BlueBlackGreenred+blueblack+green
7006101213
7009123437
70121456511
70151678715
701818910919
702111011121123
702411213141327
702711415161531
703011617181735
703311819201939
703612021222143
7039122232423
47
can some one help me with the code?
ms
Super User (Alumni) ms
Re: adding two columns and doing sum in JSL
Assuming you know how to import (or just paste) your table into JMP, it is pretty straight-forward. The example below illustrates two approaches 1) static columns and 2) column formulas. The latter will update the sum if values are changed, the former will not.
//Make example table
dt=New Table( "Colors",
  Add Rows( 3 ),
  New Column( "Numbers",
  Numeric,
  Continuous,
  Format( "Best", 4 ),
  Set Selected,
  Set Values( [7006, 7009, 7012] )
  New Column( "Red",
  Numeric,
  Continuous,
  Format( "Best", 12 ),
  Set Selected,
  Set Values( [1, 1, 1] )
  New Column( "Blue",
  Numeric,
  Continuous,
  Set Selected,
  Set Values( [0, 2, 4] )
  New Column( "Black",
  Numeric,
  Continuous,
  Set Selected,
  Set Values( [1, 3, 5] )
  New Column( "Green",
  Numeric,
  Continuous,
  Set Selected,
  Set Values( [2, 4, 6] )
//Alternative 1: static columns
dt<<new column("Red+Blue", continious);
dt<<new column("Black+Green", continious);
for each row(:Name("Red+Blue")=:Red+:Blue);
for each row(:Name("Black+Green")=:Black+:Green);
//Alternative 2: Column formulas
dt<<new column("Red+Blue2", continious, Formula(:Red+:Blue));
dt<<new column("Black+Green2", continious, Formula(:Black+:Green));
ms
  Add Rows( 3 ),
  Numeric,
  Continuous,
  Set Selected,
  New Column( "Red",
  Numeric,
  Continuous,
  Set Selected,
  New Column( "Blue",
  Numeric,
  Continuous,
  Set Selected,
  Numeric,
  Continuous,
  Set Selected,
  Numeric,
  Continuous,
  Set Selected,
