jetpeach
add tab to journal that has tabs already
I have a report with tabs that I created a journal from.
Let in script, I need to add to the journal sometimes - I want more tabs in it.
Example code is below, but it always puts the new tabs on the bottom of one of the other tabs.  The behavior I want is 5 tabs in the journal'd output.
Any help to do this? I tried add instead of append, but can't seem to find right command.
Thanks,
Joe
nw = new window("Tabs",tab box(
	tab page box(Title("test1"),text box("1st tab")),
	tab page box(Title("test2"),text box("2st tab")),
	tab page box(Title("test3"),text box("3st tab"))
nw << journal;
nw2 = new window("Tabs2",tab box(
	tab page box(Title("test4"),text box("4st tab")),
	tab page box(Title("test5"),text box("5st tab"))
current journal() << append(nw2);
Re: add tab to journal that has tabs already
Adding to the journal will do just that, add to the journal, not to the Tab Box();You need to directly reference the tab box() if you want to add to it.  Below is a simple rework of your code that is one way to add elements to the journal Tab Box();
nw = new window("Tabs",<<journal);
ttt=tab box(
nw << append(ttt);
ttt<<insert(4,"test4",text box("4st tab"));
ttt<<insert(5,"test5",text box("5st tab"));
ttt=tab box(
nw << append(ttt);
jetpeach
great, thanks txnelson. this works for me. i was misundertanding journals, thinking they were always static copies of whatever was being journaled, and hadn't thought to try adding in the way you suggested.
