add rows based on a column values in the same data table
Dear All,
I have data table that contain ID, last inspection data, and last inspection decision columns. I want to combine the last inspection data column with the last inspection decision in order to have one column (stacked) to be used in association analysis. For instance, one cluster of my data structure looks like the following:
ID             Last Inspection Decision            Last Inspection Data
101                                                             PRODUCT SPECIFICATIONS DEFECT
101                                                            CGMP Deviations
101                                                            21 CFR 211.113
101            VAI                                          LIQ_US
I would like to move Last Inspection Decision, in this case VAI, under Last Inspection Data column and create new row that has the same ID, in this case 101. Therefore I need my stacked data to be like:
ID                         Last Inspection Data
101                      CGMP Deviations
101                      21 CFR 211.113
101                     LIQ_US
101                      VAI
Moreover, some of these IDs are repeated but with different value in one or more of the Last Inspection Data. For instance, Lab DEFECT can be another problem for the same ID so I create another cluster of rows when ever any of these values differ from previous one.
101                                                             Lab DEFECT
101                                                            CGMP Deviations
101                                                            21 CFR 211.113
101            VAI                                          LIQ_US
Thank you very much for your help in advance.
Best,
Qais
ian_jmp
Re: add rows based on a column values in the same data table
I'm not sure if I have understood correctly, but here's an alternative. If it's what you want, you also need to see how well it will scale.
NamesDefaultToHere(1);
// Example table . . .
dt = New Table( "Inspection",
					Add Rows( 10 ),
					New Column( "ID",
						Character,
						"Nominal",
						Set Values(
							{"101", "101", "101", "101", "102", "102", "102", "101", "101", "101"}
					New Column( "Last Inspection Decision",
						Character,
						"Nominal",
						Set Values( {"", "", "", "VAI", "", "", "Code 1", "", "", "Code 2"} )
					New Column( "Last Inspection Data",
						Character,
						"Nominal",
						Set Values(
							{"PRODUCT SPECIFICATIONS DEFECT", "CGMP Deviations", "21 CFR 211.113",
							"LIQ_US", "PRODUCT SPECIFICATIONS DEFECT", "21 CFR 211.113", "LIQ_US",
							"PRODUCT SPECIFICATIONS DEFECT", "CGMP Deviations", "21 CFR 211.113"}
// Copy the table
dt2 = Eval(dt << getScript);
dt2 << setName(dt << getName ||" Stacked");
// Get the values from the two columns of interest into lists
ids = Column(dt2, "ID") << getValues;
vals = Column(dt2, "Last Inspection Data") << getValues;
// Find out where we need to insert new values, get the required values, and insert them into the right positions
insertAfter = dt2 << getRowsWhere(!IsMissing(:Last Inspection Decision));
for(r=1, r<= NItems(insertAfter), r++,
	InsertInto(ids, Column(dt2, "ID")[insertAfter[r]], insertAfter[r] + r);
	InsertInto(vals, Column(dt2, "Last Inspection Decision")[insertAfter[r]], insertAfter[r] + r);
// Add rows to teh copy of the table, insert the column values, and delete the column we don't need
dt2 << addRows(NRows(insertAfter));
Column(dt2, "ID") << setValues(ids);
Column(dt2, "Last Inspection Data") << setValues(vals);
dt2 << deleteColumns(:Last Inspection Decision);
ron_horne
This is not the most robust solution but give it a go:
dt = current data table ();
for each row( if(!is missing (:Last Inspection Decision),
dt << add rows(1, row()),
is missing (:Last Inspection Data), :Last Inspection Data[row()] = :Last Inspection Decision[row()-1])
It is not working as I have more than 100,000 rows. I tried to break my data to three parts, each one with almost 35,000 rows, but it is not working. Any suggestion?
Best,
Qais
ian_jmp
					Add Rows( 10 ),
					New Column( "ID",
						Character,
						"Nominal",
						Set Values(
						Character,
						"Nominal",
						Character,
						"Nominal",
						Set Values(
// Copy the table
