Pacco
add rows after selected rows
Hello community,I am new to jmp and have troubles with creating a script that would add 1 row after each selected row within my dataset. Any ideas? My code looks like this so far:
dt=Current data Table ();
dt<<add rows(1,46030);
However, this of course adds a row only after the specified column. I selected my rows according to a sepcific name in one column and a sepcific value wihtin another column. How can I automatically enter a row after all my selected rows that are not adjacent but have unselected rows in between them?
Thanks in advance for your help!
I
Re: add rows after selected rows
Because the inserted rows will change the selected row numbers, the below modification to @uday_guntupalli script has to be made to actually get the results you want.
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
dt << Select Randomly( 0.1 ); // Selecting rows randomly
SR = dt << Get Selected Rows;  // Get list of selected rows
For( i = 1, i <= N Rows( SR ), i++,
	dt << Add Rows( 1, SR[i] ); // Add 1 row after each selected row
$SAMPLE_DATA
is an special environment variable for JMP.  The structure of the OPEN() function is:
     Open( file path, <invisible>, <private>, <select columns(list)> | <ignore columns(list)> )
See below, the Scripting Index for the Open
6 REPLIES 6
uday_guntupalli
Level VIII
@Pacco,
        Welcome to the JMP Community.  Let me try and explain this and solve the problem. The Add Rows messge only specifies the # of rows and where to add so JMP is executing what the function is telling it to do. In order to scale it for your needs , we can try the following :
dt << Select Randomly(0.1); // Selecting rows randomly
for(i = 1 , i <= N Rows(SR), i++,
		dt << Add Rows(1,SR[i]); // Add 1 row after each selected row
Hope this helps and addresses your question
Best
Uday
Pacco
Thanks a lot, this script work perfectly for me.
The only thing I don´t understand, yet, is why my
dt<< open("$...");
function doesn´t work. I always have to use dt<< CurrentDataTable (); while having my table open already.
Thanks again for the valuable information!
dt<< open("$...");
is incorrect.  The specified usage is
dt = Open(:$...");
It opens up the sample data table and assigns a handle to the openned data table called "dt";
dt = Current Data Table();
does the same thing as the Open() function, except it asigns to "dt" a pointer/handle to the current active data table.
See
     Help>Scripting Index
for further details.
Pacco
Thanks for th efast Reply, however, I tried out all variations with your answer and it still gives me this error:
Unexpected "$".
Trying to parse operand for ":" operator.
Line 1 Column 13: dt = Open (:►$SMHI_Trend_IKEU_Profiler_merge_only 2
I wrote several variations like this one:
dt = Open (:$SMHI_Trend_IKEU_Profiler_merge_only 20 year.jmp");
Any ideas, what I am doing wrong? (I am a very beginner in this, sorry)
$SAMPLE_DATA
