Ted
Ted
Y Axis Specification (Format) on Survival Plot
How can I remove percent sign (%) on the Y axis on survival curve plot, i.e.:
instead:
100%
75%
50%
25%
0%
make:
100
75
50
25
0
There is no such format here:
Reliability and Survival => Survival=>
Survival Plot => Y Axis Specification=> Format
Re: Y Axis Specification (Format) on Survival Plot
JMP 13 allows the setting of the Y axis format by using the Axis Settings and a Custom format to accomplish what you want.
However, if your personal Icon is a statement of what version on JMP you are running, I do not know of a way to make that change in JMP 10
Ted
Ted
Great thanks!
Somehow I can't put kudos (?!)
