Is it possible to save this preference and make it the default for the x-axis when I'm using graph builder? I specifically need the Show tick label, long divider, show grid, and lower frame to be like this in default. Thanks.
If you go to the Column Info for the x-axis variable and choose the Axis property, I believe you can set all of the properties that you want. Whenever that variable is used in a graph, those axis properties will be utilized.
I have not found a way to save these properties for the use of ANY nominal x-variable. Perhaps another community member has found a way to do it. My only suggestion is to copy the axis settings from a variable that was set and then paste to any other column that you want to use on the x-axis.
I don't think there are preferences for those which would only apply to Graph Builder. You can change preferences but it would apply to all platforms and columns
rep = Current Report();
gbs = rep << XPath("//OutlineBox[@helpKey='Graph Builder']");
If(N Items(gbs) == 0,
stop();
// Lazy option and works for very simple cases
abs = gbs[1] << XPath("//AxisBox");
abs[1] << Axis Settings(
Show Major Labels(1),
Show Major Grid(1),
Tick Mark Style("Long Divider"),
Lower Frame(1),
Major Grid Line Color("Orange")
We also have Tags which can "duplicate" column properties, but I don't think we can save / auto-load those (I have made request this last year in Discovery Summit, no idea if it is in any lists) so no "preference" like feature from that either.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '933061' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '933061') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '933061') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
