RA899
X - Axis settings in Graph Builder
Is it possible to save this preference and make it the default for the x-axis when I'm using graph builder? I specifically need the Show tick label, long divider, show grid, and lower frame to be like this in default. Thanks.
Re: X - Axis settings in Graph Builder
If you go to the Column Info for the x-axis variable and choose the Axis property, I believe you can set all of the properties that you want. Whenever that variable is used in a graph, those axis properties will be utilized.
I have not found a way to save these properties for the use of ANY nominal x-variable. Perhaps another community member has found a way to do it. My only suggestion is to copy the axis settings from a variable that was set and then paste to any other column that you want to use on the x-axis.
Dan Obermiller
I don't think there are preferences for those which would only apply to Graph Builder. You can change preferences but it would apply to all platforms and columns
I would most likely, for now, utilize Presets, as I think they can handle cases like this. You cannot use them as defaults (Let us define which Preset to use as default on platform launch ).
Or you could create a script which would set those for either Graph Builder or as column properties like Dan mentioned.
View more...
rep = Current Report();
gbs = rep << XPath("//OutlineBox[@helpKey='Graph Builder']");
If(N Items(gbs) == 0,
	stop();
// Lazy option and works for very simple cases
abs = gbs[1] << XPath("//AxisBox");
abs[1] << Axis Settings(
	Show Major Labels(1),
	Show Major Grid(1),
	Tick Mark Style("Long Divider"),
	Lower Frame(1),
	Major Grid Line Color("Orange")
We also have Tags which can "duplicate" column properties, but I don't think we can save / auto-load those (I have made request this last year in Discovery Summit, no idea if it is in any lists) so no "preference" like feature from that either.
