nbhagroo
How do I split individual parts of a graph on JMP
Hi, I have a quick question. I want to split my graph into individual graphs for each  x variable condition. Instead of having them all complied into one graph. Can someone help me with this? I have JMP 17.
Re: How do I split individual parts of a graph on JMP
How do you want to split them?
Starting situation (both columns selected from column list and dropped at the same time to Y-axis):
Option 1 (both columns selected, drop them to Y-axis while holding shift. You can get the same graph if you drop first one and then try where you should drop the second to split Y-axis like this)
Option2 (stack your data first from Tables/Stack. Drop data to Y-axis and labeling to Y-grouping on right side):
Option3 (still using stacked data. Instead of dropping label to Y-group, drop it to Page)
nbhagroo
Hi thank you for getting back to me. This is not exactly what I am looking for however. What I more want  to do can be seen in the picture I attach here. Notice how the graph is split according to the donor. Now if you look at my original attachment I have many conditions. I want to split those conditions up like you see in this most recent attached image. Are you able to help with this? Thanks!
As I don't have access to your data, I'm not really sure what you want to visualize, but create some sort of graph with X and Y axis values, then select the grouping column which you want to use, drag it over graph builder BUT don't release the button
Then move it to different blue sections to see what it would do
I also suggest checking out Essential Graphing (or as .pdf) to learn more about how you can visualize data in JMP.
