bgotchall
Workflow step not completing before moving on
Is anyone else having a problem where a workflow step applies a formula to a column, and it moves on to the next step before finishing evaluating the current step?  I have to manually pause and wait for it to complete before allowing it to resume.  This is happening on a fairly large table, and I know it's basically fine for a small table.
WebDesignesCrow
Re: Workflow step not completing before moving on
@bgotchall
It JSL scripting it happens, where we may need to add "wait (0)" to let step complete before it moves on to the next step.
In the workflow step, you can edit the workflow script by adding wait code so that you don't need to manually pause it.
wait(0);
Example,
You can also refer to below discussions for more details;
https://community.jmp.com/t5/Discussions/how-to-do-a-smart-wait-in-JSL/td-p/537961
https://community.jmp.com/t5/Discussions/When-to-use-Wait-0/td-p/14069
For formulas you should use dt << Run Formulas() instead of wait(0) as it is its purpose and use wait(0) for other waiting tasks (usually).
Also you might want to contact JMP support about this. If there is such an issue in workflow builder that it doesn't wait for formula evaluation before those are needed, they might want to do something about it. Not sure who to tag from JMP so I'll go with @julian this time
bgotchall
Right, you would expect it to be the default behavior to finish the current step before moving on, rather than a hack you have to know.
I added a WF step with just Data Table( "Source_table" )<<RunFormulas; after the step that defines the formula, and that is doing the trick.
