hogi
Level XIII
Workflow: run selected step?
is there a keyboard short cut in Workflow builder to run the selected step?
From JSL editor I am really used to the comfort of:
select + Num-Enter
.. such that it feels kind of "complicated" to do it in Workflow Builder via
left click  - right click (menu) - left click:
Re: Workflow: run selected step?
There is not a short cut for this in workflow builder.  The arrows at the top execute the entire workflow or a single step at a time.
hogi
Level XIII
Do you think that the Developers of Workflow Builder will find this post and consider Num-Enter as a shortcut
for "run the selected steps (... and select the next step)" in a future release?
Or should I send a post to the wish list to check if other users like the idea as well?
Good morning .. I would suggest you enter the wish list request .. and then JMP can take it from there.
Thank you..
hogi
Level XIII
ok, I added it as subtopic of Presentation Autopilot (aka Workflow Builder 2.0)
