Whoops, meant to write that line as
dt1 = dtU << Subset(Selected Rows(1),Selected Columns(1));
However, it still doesn't update dt ("KrF CDU Data table.jmp"). I am trying to update the KrF data table with data from the Exposure Table (dtU).
This is what the log looks like:
Name Unresolved: name in access or evaluation of 'name' , name/*###*/
In the following script, error marked by /*###*/
Clear Log();
Clear Globals();
Close All( DataTables, "No Save" );
dt = Open( "KrF CDU Data table.jmp" );
dtU = Open( "Exposure_Summary_Data.jmp" );
dtU << Clear Column Selection();
dtU << Select Where( Contains( :Type, "KrF" ) );
Column( dtU, "F23" ) << Set Selected( 1 );
dtU << Invert Column Selection;
dt1 = dtU << Subset( Selected Rows( 1 ), Selected Columns( 1 ) );
dt << Update( With( dt1 ), By Matching Columns( name/*###*/ == name ) );
So there is some sort of error with the update line? I'm not sure, but that's what the log is reporting
