Wilcoxon test WITH Bonferroni adjustment
Dear forum users,
how can I add a Bonferroni adjustment to the Wilcoxon test?
that is how can I do post hoc non-parametric tests/multiple comparisons using pairwise comparisons like Wilcoxon rank sum test with the Bonferroni correction.
Raw-data in my dataset follows a Johnson Su distrubution, and I have had troubles transforming it into a normally distributed one, so I have to compare the groups by a non-parametric test..
Thanks
AC(Jmp 8.0.2 user)
David_Burnham
I think to do multiple comparisons using non-parametric methods you may need version 9 of JMP; taking a quick look at the method implemented in v9 I think it does not use Bonferroni corrections, so you would need to adjust the alpha of the test to acheive the same adjustment
-Dave
David_Burnham
-Dave
