BunnyBoi12
Why is my (very) simple formula not populating the column?
Howdy,
So I have a strange problem in which the formula I have set a column to is not working. I've done it countless other times before and its worked, and the formula is very very simple. The formula is pictured below. I am trying to determine the total yield of chemicals of interest, of which there are 4, so just adding them all together.
Any help would be appreciated!
dlehman1
Re: Why is my (very) simple formula not populating the column?
It's hard to tell without you provide a sample of your data.  But one possibility is that all your rows have at least one of those variables missing.  In general, it is better to use the Sum function (found under statistical functions) rather than manually adding variables - if any of the variables are missing, the total will be missing.  But the Sum function will provide the total for whatever variables are not missing.
Without seeing the data: does one of them have missing values?
dlehman1
BunnyBoi12
My bad, I'll attach it below. So its a full time course data for multiple reactors, so there are several blank spaces. And in many instances one of the chemical is present while other are not. So I think you are correct in what my problem is. Thanks!
BunnyBoi12
That's definitely what it is. I thought that JMP would interpret the blanks as zeros when using the formula. I posted the data set above in the other comment. Thanks for the help! Still trying to work out all the kinks of JMP
Missing is closer to null or N/A than 0. Depending on the calculation they will be usually: ignored or make calculation return also missing value.
Like @dlehman1 said, Sum can be used instead of Add if you wish to ignore them.
Make Sum quick formula use Sum() function instead of Add()
New Formula Column - Sum Function
