Created:
Jan 19, 2021 07:30 PM
| Last Modified: Jun 11, 2023 4:10 AM(2767 views)
I am having a hard time figuring out how to darken the bars in my bar graph. Anyone out there have a solution for this? Attached is the graph I am currently working on.
I assume it is because some of the rows in your data table are selected and therefore, any data from the rows that are not selected will be diminished in color. This is a standard JMP feature.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '350932' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '350932') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '350932') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
