Why is it this doesn't work?
:Name("COLUMN_NAME+WITH-CHARACTERS")
OK
str = "COLUMN_NAME+WITH-CHARACTERS"
:Name(str)
Error: Name arg must be quoted string
The only way I've gotten this to work is:
eval(parse(":Name(\!""||str||"\!")"))
which is absurd
pmroz
I use the column function instead:
column(str)
For clarity I include the dataset name as well:
column(dt, str)
Sometimes I've needed to use the as column function.  Not sure if it applies here.
Regards,
Peter
pmroz
column(str)
column(dt, str)
Regards,
Peter
ccp
ccp
Can you also add some info on the usage of "As Column"? I am trying to pass a column name as a variable to the Split Table function, and I think the "As Column" function will help me do this. What I am trying looks something like this:
columnname = "data1"; // assume there are multiple columns of data like this, data2, data3, etc.
Current  Data Table () << Split ( Split By (:DAY) ), Split (columnname) .... );
I think I need something like an As Column (columnname); statement in there...
Suggestions?
Thanks,
Charles
pmroz
I'm not sure why you need COLUMN vs AS COLUMN.  It seems to clarify things for JMP.  I mostly use the COLUMN function, but I needed to use the AS COLUMN function in a where clause:
one_dme = "Electrolysis";
tmp_matrix = dmt << get rows where(:Time Period == "Current"
                                   & as column(dmt, eval(one_dme)) == 1);
ccp
ccp
@PMroz
Thanks for your help. I could not get As Column to do anything for me, but your use of "eval" got me thinking, and I was able to get this syntax to work:
Current  Data Table () << Split ( Split By (:DAY) ), Split (eval(columnname)) .... );
Thanks,
Charles
XanGregg
FYI, Name() isn't a real function (despite the way it looks); it's a quoting mechanism handled by the parser. If you really want to create a name at run-time, use the As Name() function.
