abdulj
Copying Columns and Column Names to a New Table
Hello
I'm having a bit of trouble selecting columns from a data table and copying them to a new blank table.
So far I'm stuck on how to even copy the column names to the new table.
In my workflow I prompt the user to select 2 data column from an existing table using the column dialog function, then from there attempt to move everything over.
Here's the code:
CD = Column Dialog(
          Col1 = ColList( "Select First Data Column", Min Col( 1 ), Max Col(1) ),
          Col2 = ColList( "Select Second Data Column", Min Col( 1 ), Max Col(1) )
RemoveFrom(CD, 3);
name1 = r1["Col1"];
dt = New Table();
dt << New Column();
Column(1) << Set Name(char(name1));
When I use the show() command to Show(name1) I get:
{:Name( "Outer length-A-1" )}
Instead of just "Outer length-A-1"
Which means my column name ends up being {:Name( "Outer length-A-1" )}
How do I reference just this name??
Also, is there a built in function for simply copying the entire column to my new table??
thanks
pmroz
This uses the subset command and might be a little simpler:
dt1 = open("$sample_data\big class.jmp");
col_dlg = new window("Column Copier",
      panelbox("Select two columns to create a new table with:",
            col_clist = collistbox(all, width(200), max selected(2)),
      buttonbox("OK",
            selected_column_list = col_clist << getselected;
            col1 = selected_column_list[1];
            col2 = selected_column_list[2];
// Create a new table using just the two selected columns
            dt2 = dt1 << Subset( columns(column(dt1, col1), column(dt1, col2) ) );
            col_dlg << close window;
ms
Super User (Alumni) ms
Re: Copying Columns and Column Names to a New Table
I think the easiest would be the subset() command. You get both the column names and data in one sweep.
dt1 = current datatable();
CD = Column Dialog(
RemoveFrom(CD, 3);
dt1 << subset(
          rows( 1 :: N Rows( dt1 ) ),
  Eval List( CD ),
          Output Table Name( "e.g. New Table" )
pmroz
      buttonbox("OK",
abdulj
Great thanks for this.
Another new function I now know about.
