lehaofeng
Level V
Why does the order of the values in matrix scb4 change when added to a tablebox?
Why does the order of the values in matrix scb4 change when added to a tablebox? How does it not change? And a second question, can the order in tablebox be set according to two columns, now it is provided as one column. Thanks!
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
ps = dt << Process Screening(
	Grouping( :Site ),
	Process Variables( Eval( 5 :: 132 ) )
tb = report(ps)[Table Box( 1 )];
delta = Matrix( Report( ps )[Number Col Box( "Mean" )] << get ) - (Matrix( Report( ps )[Number Col Box( "USL" )] << get )
+Matrix( Report( ps )[Number Col Box( "LSL" )] << get )) / 2;
scb4 = Number Col Edit Box( "distance", delta );
a=scb4<<get;
tb << append( scb4 );
b=scb4<<get;
c=a-b;
Re: Why does the order of the values in matrix scb4 change when added to a tablebox?
My guess is that because you are appending it to a platform it will for some reason use default ordering. There might be a lot going on what you cannot see when you are directly manipulating JMP platforms like that. You could maybe use Clone Box to get the table and append to that (depending on what you are doing).
ps = dt << Process Screening(Grouping(:Site), Process Variables(Eval(5 :: 132)));
tb = Report(ps)[Table Box(1)];
delta = Matrix(Report(ps)[Number Col Box("Mean")] << get) - (Matrix(Report(ps)[Number Col Box("USL")] << get)
 + Matrix(Report(ps)[Number Col Box("LSL")] << get)) / 2;
scb4 = Number Col Edit Box("distance", delta);
nw = new window("",
	tb1 = tb << Clone Box;
a = scb4 << get;
tb1 << append(scb4);
b = scb4 << get;
c2 = a - b;
a = scb4 << get;
tb << append(scb4);
b = scb4 << get;
c1 = a - b;
Maybe you could first append the Number Col Edit Box and then set the values to i
tb = (report(ps)[table box(1)]);
scb4 = Number Col Edit Box("distance", {});
tb << append(scb4);
scb4 << Set Values(delta);
wait(0);
tb << Sort By Column("Stability Index", 0);
I'm not sure how easily this would break when you are performing different actions within Process Capability though
nw = new window("",
a = scb4 << get;
b = scb4 << get;
c2 = a - b;
a = scb4 << get;
tb << append(scb4);
b = scb4 << get;
c1 = a - b;
lehaofeng
Level V
Thank you very much! It's already solved most of the problems. I would very much like to be able to add it to the original platform so that the commands on the platform can be used as well. But anyway, this is already very good too!
tb << append(scb4);
wait(0);
lehaofeng
Level V
Thank you very much, very useful!
